2.5" lift vs 3.5" lift
2 Door 3.5"
I'm Running 4" net from my piecemeal of parts I call a lift. 315/70/17 is about 34.5" With flat fenders I have no rubbing at Max Flex. I was rubbing on stock fenders with a trimmed pinch seam. I have about 6" or a little more of flex. I would recommend a 3.5" lift If your planning on going bigger in the future.
Going higher can get you more out of the muck in deep holes--your electronics may appreciate that. Mud/sand will be very hard on your Jeep--anticipate brake caliper problems, bearing failures, damaged axle seals, even ground down axle shafts (at the seals)--I've experienced it all running quicksand-filled rivers here in Oklahoma. But, other than running large enough tires to get your axle shafts higher, you're at the mercy of the elements.
There is a sticky by Dirtman called "My thoughts on lifts". It is a very informative read--highly recommended. Good luck with your decision.
Going up!
I just wrapped up the AEV 2.5 lift and spacers..yeah i know.. spacers..eh... anyway I am 6' am think the 2.5 is a pretty modest lift. I would have liked to go with a 3.5 but it's all good, I can still put 35s on it! I bring up my height because when i got back home after doing the install I kinda forgot how much further it was off the ground and rolled my fat ass right on out and on my face lol. SO yeah.. it's a bit of a change, not too bad imo.
I started with a 1" coil spacer lift. After a few months I replaced it with a 2.5" proper coil lift. Then, a few weeks later I took my spacer lift and added it to my coil lift. So, I'm at 3.5" of lift now. I know I am risking damage to my drive shafts, but it's a risk I'm willing to take and I can handle the repair expense if I need to.
My advise is to go 3.5" if you can afford to replace broken parts. Otherwise, stay at 2.5".
I started with the teraflex leveling kit then moved up to the RK 2.5 max travel system. I have been contemplating throwing one of the 1" spacers from the leveling kit up front as, to my eye anyway, there is still a slight rake. Problem is I think a full 1" will create a rend end low look. Anyway, might put a 1" spacer on both ends to get a bit more height...just for looks really. Have you had any issues? I know the known issues but did it change the on road mannerisms much? I will not do it if it does, the RK kit handles the road really well. I have an unlimited btw if that makes a difference.
You probably know this already, but you can get a 1/2" or 3/4" spacer for the rear if you are concerned about rake.
I just added the spacers a couple weeks ago, so I don't have a ton of experience with this setup. The road handling seems to be the same. I do stumble getting in more than I used to!
