2.5 lift 37s rubbing question
Old 09-29-2013, 04:31 PM
Insidejob01's Avatar
Originally Posted by Jeepstin12
ok. I recant. Clearance. It's clearance needed.
I actually tried to get solid responses for running 35's, no lift and smittybilt fenders. People still insisted on the lift. :(
I would run 35s stock hight in a heartbeat! Flat flares and a little trim and you got it
Old 09-29-2013, 04:36 PM
kh202's Avatar
I've often thought about dropping the budget boost. But the extra little height does help. Def never thought about going higher
Old 09-29-2013, 05:33 PM
Jeepstin12's Avatar
i ran them, with some trimming, and I rubbed, a lot. And that was just street driving. With 4 passengers, I rubbed on dips in the road. Off cambers, far worse.......
Old 09-30-2013, 04:55 AM
5110's Avatar
What were you running for wheels? Bs?
Old 09-30-2013, 10:58 AM
Ker-B's Avatar
I cut off the forward big portion of the pinch seam and trimmed my rubicon rails, then used a BFH to fold the pinch seam up and out of the way, then spayed bedliner rattle can over it all. 2" bump stop extensions. running 37" MTR's and an AEV 2" spacer lift. can't remember exact back spacing though... No rubbing at full stuff with sway bar disconnected.
Attachment 501530Attachment 501534
Old 09-30-2013, 12:22 PM
Monte417's Avatar
Your attachments for some reason arent opening. im getting these tires in a couple days and curious as to what your trim looks like. I cut my pinch seams when I got my 35s and have aftermarket rock rails
Old 10-01-2013, 07:36 AM
Ker-B's Avatar
Don't know the deal with the pics. I cut just the front and rear parts at first but after flexing I had to beat the whole pinch seam all the way around flat against the rest of the wheel well. I used 2x3 steel tube for the bump stop extensions.
Old 10-01-2013, 08:00 AM
Monte417's Avatar
Wow ok gotcha thanks
Old 10-01-2013, 05:28 PM
Wish I could see pictures of the cutting you did...
Old 10-07-2013, 08:50 AM
Ker-B's Avatar
trying again. its a bit muddy from the weekend but hope these work and help.
ID:	503268   Click image for larger version
ID:	503272   Click image for larger version
Quick Reply: 2.5 lift 37s rubbing question
