2.5 budget boost...
2.5 budget boost...
So i raised my jku 2.5" and added shock extenders too. Somewhere in the im getting a squeak or rattle constently!! Im assuming its the spring?? Anyone have this issue and know of a quick fix or a fix for it??
Did you loosen the control arms ? If you did, it is very important to re-torque them when the Jeep is back on the ground instead of while it's jacked up. It will make the bushings bind.
Im not quite sure what was loosened. What ever i had to do to lower the suspension to remove the coil and pit it all back. I added the extenders seems like it coming from the back driver side only.
