2.5 bb lift with no shock extensions
Old 12-08-2014 | 09:22 AM
dtcercado's Avatar
Default 2.5 bb lift with no shock extensions
Just wondering is it required to have shock extensions when running a 2.5 bb lift? I have stock rubi shocks with my bb lift on. Will anything get messed up when sway bar disconnected up front?
Old 12-08-2014 | 10:21 AM
nthinuf's Avatar
A 2.5" lift with stock shocks means the shocks will always be extended. Disconnecting seems kinda pointless...
Old 12-08-2014 | 11:29 AM
dtcercado's Avatar
Nthinuf so I should probably install some shock extenders?
Old 12-08-2014 | 11:39 AM
arasco85's Avatar
yes, Your shocks will be completely extended at regular height, or close to it. Your shocks would be topping out every bump. So you'll have a shitty ride and probably ruin the shocks. Disconnecting would be pointless as the shock would be restricting the down travel.
Old 12-08-2014 | 11:45 AM
dtcercado's Avatar
Cool thanks for the help guys! Will get some extensions installed.
Quick Reply: 2.5 bb lift with no shock extensions
