2.5" AEV setup question
I have the 2.5 lift on my two door. i netted exactly 3". I didn't use their brackets becuase i have after market lower control arms. After 4 months my lift has not settled at all so i would not bank on that too much.
Dstock,
If you look on page 3, line #5, it says that if the measurement is between 6 1/2 and 8", use the middle hole. Mine is actually 6 3/4. I called AEV and they said that sometimes thier 2.5" lifts will net more than 2.5", in which case, the middle hole should be used. Of course mine is kind of in that gray area. I suspect that once the springs settle in a bit and I add a bumper, it will bring that measurement back down. Easy enough to try it in the middle hole though.
Appreciate the input.
Thought I would report back on what I found out. I moved the upper control arms to the middle hole on the brackets this aftnoon and it solved my issues. No more wandr! i also stopped by the dealer today and measured a couple of stock Saharas as a reference and I ended up with 3.25" of lift out of my 2.5" AEV.
The funny yet sad thing is that the dealer, who actually does install many lifts, was bragging about the master mechanics that double checked my install. Sometime you just have to do it yourself!
