2.5 to 4 inch build
2.5 to 4 inch build
I'm currently running the Teraflex 2.5" coil lift with shock extenders and front Teraflex LCAs. I want to go to a 4 inch lift, but want to build it up as money allows and do it the correct way. I figure I need the following:
Front driveshaft
Shocks (debating Elka, Fox or Bilstein)
Brake line extensions
Question... Do I need the following:
Rear control arms (lower, upper or both)
Adjustable trackbar (front, rear or both)
Swaybar links (2.5 lift came with rears, but I assume they are sized for the 2.5 lift)
Anything else I am leaving out (aside from the obvious springs)?
Front driveshaft
I did this and what I learned was you will need to upgrade a lot of components going from a 2.5 to a 4 lift. I added new coils, then all 8 flex arms to get everything centered to where it should be, then addressed the steering issues and added a flipped Currie steering kit with sector shaft brace and a Currie tie-rod. Finally adding a rear adjs trackbar and repositioning the rear coils because they will bow at that height. That finally got everything squared away and it drives like a dream now. Dialing everything in is the biggest part.
so to obvi answer your ?'s yes I'd get new sway links, all arms if $$ allows, if not then front lowers and rear uppers, and both trackbars. I'd also op for the TF rear trackbar brace to compensate for stress on the rear trackbar with a lift over 3"s
I just went from a tf 2.5" lift to evo 4" springs. I installed the springs and am doing what i can little by little. All i have added so far is front track bar and front lower control arms. No problems yet but next is longer shocks and brake lines. Thats all im going to do until i go long arm.
Sponsoring Manufacturer
I'd make it my last step if it was me. Unless you have a 2012, then I would swap those last. You can easily run stock drive shafts on a 4dr with a 4" lift. You will need longer swaybar links also for the front. TeraFlex uses the same 12.25" rears in 2.5"-4" kits.
What would you suggest I do as first steps? Longer shocks? The other control arms?
