2-3" Coil Lift without drilling
Is there a decent 2-3" coil lift that doesn't require drilling? So far from what I can see, every coil lift requires drilling, but looks like none of the BB's do.
That being the case, I may do a cheap BB for now and do a coil lift after the warranty expires.
As long as your using adjustable track bars, I don't think that you should have to drill. Someone correct me if I'm wrong, but the only driling that I really had to do on my JK with the Skyjacker was for the relocation brackets for the track bars of which adjustable track bars would make that a non issue.
The only drilling I did was for my front bump stop extension. I had to make a small hole for the self tapping screw.
http://project-jk.com/images/writeup...e/DSC02679.jpg
