16" wheels on a Rubicon?
Does a Rubicon have larger brakes than an X that would cause rubbing?
I've seen more jeeps on here with 17's than 16's, is t there a reason people are running larger wheels? I had a TJ eight years ago and back then everyone was running 15's.
Jeep put 16 and 17's on factory is why your seeing the bigger rims,
Some 15's will fit, some wont
Larger wheels are required on JK because it needed larger brakes than the TJ.
Larger brakes were needed because:
1. The JK is heavier than the TJ (bigger vehicle, stricter impact regs, more standard content).
2. More was expected from the JK braking performance, than TJ.
3. JK had to meet stricter federal braking requirements than TJ.
Also, as has been stated above, ride and handling targets also dictate wheel size.
A great many of us know from experience that 15" wheels do fit. If those guys behind the counters ever tried it, they would know too. If all they do is look at the manufactures spec chart, then it will say no, and usually be wrong.
I have 16's
Just so you know, I have a Rubicon and 16" ProComp wheels with 4.5" of backspacing. They fit fine with no problems whatsoever. I used to have an 07 X and tried 15" Cragar steelies with 5" of backspacing. They did not fit. But to answer the initial question, yes, 16" wheels will fit on a Rubicon.
This is the common knowledge misinformation that gets passed around as fact and spouted by the guys across the counter at the tire store. It sounds so authoritative, but is simply incorrect. Since JK Rubicons came with 17" wheels, it must be the smallest that fit. WRONG. This forum has much more knowledgeable folks than your local tire shoppe, or even your local 4x4 specialty store. You do have to sift through the chaff, however to find the truth.
Oh boy, where do I start???
You read what you wanted to read, so I'll start by sifting thru a little chaff for you and painting the picture a little more clearly.
You infer that I am a counter jockey at a tire store, or at the very least do not know anything because you've notice that I am an FNG (long time lurker).....Until recently I was the brake engineer on the JK. I was on the program from the initial idea for a new Wrangler, until last year...(2003 - 2008). I guess that I could be considered the most authoratative source on JK brakes that you will find.
I'll agree with you about inexperienced parts guys / tire guys at the big box stores..if it's not in the computer, they are generally useless.......
The smallest wheel size is dictated by the size of the brake package required to meet corporate and federal braking requirements on the worst case vehicle configuration (factored for GVW, C.G. height, tire size, etc.). JK has 1 foundation brake system, all calipers and rotors are the exact same on X, Rubicon, and Sahara. If you've done your homework, you will know that the smallest FACTORY wheel offered on a TJ was a 15" and the smallest FACTORY wheel on a JK is 16" (X pkg). LARGER WHEELS ARE REQUIRED ON JK BECAUSE IT NEEDED LARGER BRAKES THAN THE TJ. .
Why were larger brakes needed? Because:
17" on Rubicon and 18" on Sahara had nothing to do with the brakes. On-road handling and styling whims rule for the larger diameter wheels. If you so desire ( and can stand the ridicule), you can mount factory 16" wheels to your Rubicon or Sahara and live happily ever after.
For those that find a 15" wheel to fit a JK, great. For those that have tried 15's and they interfere with the brakes, please do not grind the caliper. Get a thin spacer instead, or the best course is to find a different wheel that fits without interference. Not entirely sure why you think you need 15's, (is that extra 1/2" of sidewall on a 35 or 37 really going to make or break you??) but Happy Wheelin anyway!
Regarding why people want to run 15's, I think it's because they are so much cheaper. A 15" Crager wheel is $40. Tires for 15 inch wheels are $70-80 less for each tire. Also, there are almost no options for a C-Rated tire bigger than 32's on a larger wheel. Who wants to ride around on tires with an E load rating?
