15" Regrets
Old 04-30-2014, 06:45 PM
PG-JKU's Avatar
Originally Posted by stagedtrip
Did that and snapped the caliper clean off leaving on bolt in with the head sheared, but that's why they sell easy outs.
15".
It doesn't matter what ya run, if ya play hard shit happens
Attachment 549800
ouch! That hurts!
Old 04-30-2014, 07:33 PM
revvinkevin's Avatar
The only thing I don't like about my 15s is it limits choices for tie rod upgrades.
Old 05-01-2014, 12:57 AM
Mark Doiron's Avatar
And if you might be interested in bigger front brakes, believe that they require at least 17" wheels.
Old 05-01-2014, 02:18 AM
OH9JK's Avatar
I have been running 15" wheels for a few years now. My wallet thanks me all the time and the Jeep doesn't care....so yeah no regrets.
Your options for tires above 35" are limited but there are options.
Old 05-01-2014, 05:25 AM
Mangrove Mafia's Avatar
No regrets here either. Just be mindful when having the wheel/tire balanced that the stick-on weights will rub the caliper if placed too far towards the back of the wheel. That's what I'm currently experiencing (tires were mounted/balanced and sent to me from DTD). Other than making a slight noise, no issues that I've noticed.. Caliper is beginning to wear a groove into the weights so the noise should eventually cease.
Old 05-01-2014, 10:43 AM
Work in Progress - JK's Avatar
x2 on Discount Tire, that's where my rim and tire setup came from.
You will be fine with alloy wheels, but if you try steel rims it will depend on the weld (some may rub and other rims may not).
The tires on a 15 are less than same tires on a 17 - I looked both ways and by the time you buy 'good' spacer pucks the price of a alloy 15" rim with 35's are close to a wash and way easier to rotate, etc.
Name:	My JK lifted 006 Comp.jpg
PS: NO regrets!!!
Old 05-01-2014, 11:34 AM
bmartin4's Avatar
So you have to buy spacers if you are going with 15's
Old 05-01-2014, 12:00 PM
PG-JKU's Avatar
no you would just get 15's with the correct backspacing. You would need the spacers if you are keeping stock rims but going bigger with the tires.
Old 05-01-2014, 12:10 PM
Black2013JK's Avatar
Someone has to post the link up, right?
Discount Tire Direct- 15" Alloy Wheels VS. 15" Steel Wheels
Old 05-01-2014, 06:04 PM
951JEEP's Avatar
For what its worth, I'm like everyone else who has responded....NO REGRETS here either!
Quick Reply: 15" Regrets
