15 PSI with 285 and stock wheels
Old 07-03-2009, 04:42 PM
rcdude3's Avatar
Originally Posted by Troysterr
You should be fine on Kane Creek, as long as you're with a group and someone with you knows the trail well. It's easy to get lost.
Moab Rim might be tough in a 4-dr, but I'm sure you could do it.
i have done KC about 5 times before on my ATV, and i did it in my JK with no problems. had the tires at i think 16 PSI... idk. also did Hells Revenge, again, and Fins and Things in the JK instead of ATV.
Old 07-04-2009, 02:32 AM
pearl-drum-man's Avatar
Originally Posted by rcdude3
Right now i am running my 285/70-17's at about 17.5 PSI or somewhere in there...maybe 18. I was wondering if i could run my tires at 15 PSI. I have the factory 17" wheels. lol this is for the trail. the tires are KM2's and i have a 4 door if that helps.
15psi should be fine, do it without issue on my stock wheel/tire size combo. If anything the 285's will hold the bead better.
Old 07-24-2009, 04:08 AM
Hockeybomb77's Avatar
What about 305/70r16 on stock 16 in rims?
Old 07-24-2009, 04:16 AM
bostonMA's Avatar
I would keep it between around 15 and no lower that 12 given that you have the 4-door.
Quick Reply: 15 PSI with 285 and stock wheels
