15" MT II rims will they fit?
Please see the attached:
http://www.mickeythompsontires.com/W...Guide_2007.pdf
Mickey Thompson does not make a 15" wheel for a JK, only a 16x8, 17x9, and 18x9. Your lug pattern is 5 on 5.
No, they will not fit.
Yeah, of course you can use wheel adapters. Some people do not like to use them. I've ran them before, not on the JK, on a TJ. They work fine, just make sure you check the torque on the lugs about every 500 miles or so. Just to be on the safe side, nobody likes to have a wheel pass them on the freeway:-) Good luck man, post some pics when you get them installed.
i agree. also some are having leverage issues with front bearing housings bending. the jk fender wells are so big i think you get a morew proportionate look with larger rims anyway.
