15 inch wheels and MUD...
On another note... The one reason I do regret 15's is depending on how serious your going with your build some aftermarket HD tie rods and steering components require larger wheels because their mounting locations are so close tho the wheel when mounted
That was enough for me. If it's going to be that tight, go with 16" or larger.
I've had 15's on my previous 2 Jeeps and the only time I ever had this issue, everyone else on the trail regardless of wheel size did as well. Some mud is just gonna cake in more than others. The 15's aren't gonna be any worse than the others. They just make for cheaper tires, hence the salesman is telling you to go with a bigger wheel. They get more money out of you that way.
