15" Cragers arrived = arghh, the calipers rub
#22
Dont use the spacers at all get a grinding disc and grind it down a little, I was apprehensive at first so I bought soacers and they absolutly were dangerous as f@#k. took longer to unbot the tire than it did to do the grinding, trust me it is worth the piece of mind when you are doing 100kms down the highway and you dont have to worry about breaking a wheel stud or the lugs comeing loose.
#24
#30
Not to sound dumb, but I take you you just grind till the brake caliper till it is flush with the base of the lugs/drum?
After all this is where the wheel sets.
Should I spray brake cleaner on the brakes after I grind the calipers in case any fragments from grind get on them. Probably falls right off anyway right?
