13mm Unit bearing bolt question
Old 09-07-2016 | 03:28 PM
steelzeppelin's Avatar
Default 13mm Unit bearing bolt question
I broke off a unit bearing bolt while preparing to install new ball joints. Does anyone know where to get new ones and the best way to get the remaining part of the bolt out? I am stuck, any advice will help.
Thank you
Old 09-07-2016 | 04:13 PM
kjeeper10's Avatar
Vet Army
I may have a few PM your address
Old 09-07-2016 | 04:31 PM
jadmt's Avatar
JK-Forum Ambassador
If you have an air chisel hit the broken stud with a blunt end chisel and it will pop right out. Just support the retainer in a vise or similar. A large vise and socket will work to replace the new stud. If you try and suck it in with the nut you can screw up the threads
Old 09-07-2016 | 05:05 PM
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
I think you're talking about the wheel lug nut stud, and OP is talking about the three twelve-sided 13 mm bolts the hold the unit bearing to the axle flange.
Assuming the latter, you're able to remove unit bearing with busted bolt in it. An easy-out is one way I've used--just ensure to drill in center and straight. You can also use a chisel or die grinder or Dremel tool to make a slot in the top of the broken shaft, then use a screwdriver to turn it out. If using die grinder, be cautious to minimize cut into unit bearing material. My experience is that banging and twisting will make it easy to turn out once you have something to grab onto. A little penetrating oil will help, as does a certain measure of cussing.
SoCaLJeepFiendz (04-14-2019)
Old 09-07-2016 | 08:09 PM
jadmt's Avatar
JK-Forum Ambassador
Duh lol not sure I was thinking I had the rear retainer on my mind lol.
Old 09-08-2016 | 04:07 AM
Panhead5's Avatar
Trying to figure out how one of those broke off . I'm going to be changing my front axles and maybe need to pay better attention than I thought I would !
Old 09-08-2016 | 06:40 PM
I used my breaker bar and it started to turn then tightened up a little and snapped. I'm shipping my Jeep from Maui to Seattle in 8 days. This is not a fun jon
Old 09-08-2016 | 07:09 PM
karls10jk's Avatar
Getting the remaining piece out will depend on how much is left in there.
The ....13 and newer IIRC, have a smaller diameter head on the bolt. If you buy old bolts you may have to grind them to fit. You shouldn't have problems with new bolts.
And it's possible to drive / ship it with just 2 of the 3 bolts in place if you need to do so. I wouldn't suggest making a habit of it but if you *need* to do so then it won't kill you.
Old 09-09-2016 | 06:38 AM
kjeeper10's Avatar
Vet Army
Picked the best two and blasted. Will ship today.
Old 09-09-2016 | 09:24 AM
Chuck-The-Ripper's Avatar
You're one sweet son-of-a-bitch, Ken!
