13.50" wide 37s on 4.5 backspace question
Can I run a 37x13.50 on a 4.5" backspace 10 inch wide rim -12 offset. The Jeep goes in to the shop in 2 weeks for a bunch of work and I am ordering the tires to be shipped there - I want to go with the 37x13.5 - will I have any problems, anyone have an experience with similar stats.
Thanks
Thanks
Thanks - I was really trying to stay away from wheel spacers….now I have a decision to make by the 29th…
Dirtman's posts lead to a 3.5" backspace, so 1" would (in therory) fix it.
You can try it out, but certainly be prepared mentally and so forth.
- New rims with the proper backspacing.
- Add washers to the steer stops and go slow any time you turn and compress the suspension. (turning up/down into driveways or turning while crossing dips in the road, etc)
- Ignore the rub.
Same situation with my new 37's and old 4.5 BS rims. Couldn't find any 16" rims with less than a 4" bs, so ended up with a set of spidertrax and --> no more rubbing.
I have 37 toyos and 4.5 bs rims. I had to add as mentioned some washers on the steer stops. Can't remember exactly but I think two or three did the trip. I have no rubbing on the arms at full stuff.
man sometimes i hate my stretched 2 doors steering radius, i cant imagine a 4 doors let alone adding steering spacers...some trails id have to do like a 9 point turn there if i had a 4 door. personally id get new rims or spacers, essentially its the same thing in my opinion.
Thanks guys! Great info - question on the steering stops, how does that change turing capability - is it drastic or something I prob wouldn't even notice…any feedback appreciated.
