10k for suspension were to start?
Sponsoring Manufacturer
Thanks
Ultra 4 is the class of trucks they run in king of the hammers. It is built to handle high speed and rock crawling. A new rig will run you $100k+ depending on the set up I have seen used ones in the $20k-$50k price range.
I cant recommend my fab guy enough!!! His name is Kenny and he does the work out of his garage! He had my jeep done in about 45 days. He 3 linked my front and rear suspension with 14" King IBP coil overs, did PCS hydro assist ram, and did custom welded on sliders. Recently he has added bump stops to the rear and installed my PCS steering pump. My suspension is a one off and works great. He will sit with you and discuss what you want and the possibility of making it happen. He charged me 1K for the front and 1K for the rear. All the little things,, like sliders and bump stops are very cheap. By the way,, mine is my daily driver! He is able to fab up whatever you want. To see his work you can go to Ruggedrocks.com and look at the build threads started by "The King". He has done nissans, TJ's, my JK, and a couple of rock buggys. His buggys range from his own 10K budget build,, to "Showtime"'s 150K hammer racer. PM me if you want his #. Good luck with your build! Start a thread!!
