1" front coil spacer (puck) Help please...
Old 05-06-2011, 03:12 PM
  #21
MotiCross's Avatar
Default One more question..
can i add 3/4" to the front just by changing the front springs? if so , how? what would i need..?
Thanks again
Old 05-06-2011, 03:22 PM
  #22
Bosox5's Avatar
Thanks again
http://www.teraflex.biz/jk-1-5-perfo...eling-kit.html
I would go that route if you just want to level it out. The new TF 2.5 Coil lifts are supposed to level the JK out too if you wanted to go that high.
Old 05-06-2011, 03:31 PM
  #23
MotiCross's Avatar
will this work ok with the stock shocks..? sorry for all the maybe dumb questions and thank you so much!
Old 05-07-2011, 02:48 PM
  #24
MTH
MTH's Avatar
I measured the front and back from the ground to the fender and the differance is actually a bit off from left to right... on a level surface... maybe the tire? not sure...
Not unusual. Probably the gas tank. If it was near full or near empty, that's a 22 gallon swing on just the passenger side.
Anyways, it is a roughly 3/4" differance so i decided to go against the 1" at this time... if you or anyone you know have photos of a JKU with only a 1" puck in front please show me a photo so i can make up my mind before i lose it.. lol
M
Back-to-front or side-to-side? If back-to-front, then DayStar makes 3/4" front spacers. Problem solved.
Old 05-07-2011, 02:57 PM
  #25
arasco85's Avatar
Im sure it will settle a little. Wont even notice it.. just do it already!!
Quick Reply: 1" front coil spacer (puck) Help please...
