1" front coil spacer (puck) Help please...
Measure your jeep to see just how off it sits. I put a 1" puck in the front and it is still lower in the front than the back but is close enough to even. (And that is with stock bumpers)
i acullay think you will love it with the puck, i installled the leveling kit witch is 2 inches in the front, i have a heavy winch and bumper and it really made the jeep look better!! you cant go wrong with this and the jeep still handles and rides the same.
ok done. i'm doing this tomorrow.. if i dont like it.. i'll take it off.
I'll keep you all posted. Thank you so so much. pics coming soon.
BTW do any of you have pics or know someone with pics of the 1" leveling spacer installed?
Thanks again
Thanks again
If u dont like it, install a 1/2 inch spacer in the rear instead of removing the front. The rear is no harder than the front. I installed andditional spacers front and rear along with rear coil correction wedges couple months ago in friends garage and we knocked it out in an hour front and rear. Once u have done it 3-5 times, u get fast at it.
I put in Mopar HD coils (19/60) and DayStar 3/4" spacers both front and rear, and now the rake is only .5" out of level. So if I added another 1" the Jeep would be overcorrected and--in my humble opinion--look like it's taking a dump.
Does anyone have pictures of 3/4" or better yet, 1" spacer front only.
I was thinking about the 1" and bought it because i figured most lifts (spacer lifts)
are off by 1" from the front and rear pucks..
so...
I measured the front and back from the ground to the fender and the differance is actually a bit off from left to right... on a level surface... maybe the tire? not sure...
Anyways, it is a roughly 3/4" differance so i decided to go against the 1" at this time... if you or anyone you know have photos of a JKU with only a 1" puck in front please show me a photo so i can make up my mind before i lose it.. lol
Thank you all.
M
Thank you all.
M
Thank you all.
M
Thank you all.
M
i got my tires used and the back is much worst than the front. so i'm thinking once the new tires go on (2-3 month) it will be about an inch .. plus i havent done the allignment for the new tires since they were used and i got a great deal on them...
http://project-jk.com/jeep-jk-write-...-end-alignment
