1" BL on 2011 jku ??
#21
Originally Posted by Cdyspeed
What BL did you go with?
#24
Inner Boot Mod
I installed 1.25 rc body lift with shift adapter and rear bumper relocators. The gaps are not noticeable.The rear bumper extensions help that.But the shift adapter is not perfect. You will probably have to change the cover of your stick, with a custom one cause the adapter comes in contact with the cover when you select 1st,3rd,5th. Not a huge problem but an issue to think about. If you dont install the adapter you will not be able to select 4th without popping even if you go with only 1inch body lift. I have an 2010 Jk 2dr manual.I dont know if there is a difference between 2010 and 2011.
http://project-jk.com/jeep-jk-write-...ation-write-up
#26
Here is the before I already did one side but you can't see it really good so I'm going to do this side and post the same pic but with it installed
#28
Damn ouch!! Do you have a vice, if so open it up just a little so the mount sits on the top of the vice flush and the bolt is i'n the opening and then hit with big hammer . That way it's not going to move when you hit it and smash your thumbs!!! Don't ask me how I know lol
