1.5" wheel spacers question
so I am going to install a TF 2.5" BB. i have heard if you use the stock rims/tires you dont have to get spacers if you just reverse the rear links? if that is true, that will be great as I cant put new rims/tires on for another 6 months or so.
if I do by wheel spacers to make my stance a little wider, can i still use the spacers later with aftermarket wheels or will this make the stance too wide? i would want to add soft 8s in the future.
thanks!
thanks!
Reversing the rear links?
The track bar links?
What would reversing them do and how would that effect the wheel spacing?
Maybe it's me, but this doesnt make sense.
depending on how wide the tires are. A 12.5 on a stock rim rubbed on mine. I ended up using wheel spacers. With a new rim you can get the right back spacing, then sell your spacers.
What size tire are you planning on running? not sure how the trac links will keep the outer diameter or the tire from rubbing I have to look under the Heep to see if they are closer to the tire than my TJs.... to answer your question about spacers you can run them with aftermarket wheels but there will be no need. I would just sell the spacers when you get new wheels
I have 35x12.5x17 on the stock wheels. If you run the stock wheels without spacers they will rub. I like the look of the stock wheels so I used a set of Rough Country 1.5" spacers, very easy to install, stance is great. If you end up buying a new set of wheels down the road, purchase a set with the correct back spacing built into the wheel, you will not need additional spacers.
check here; https://www.jk-forum.com/forums/show...077#post974077
I could not fit the TF BB with stock wheels in ANY configuration when putting on the longer swaybar links.
I did the BB and just swapped the links out after the spacers arrived and where put on.
