1.5 spidertrax wheel spacers
If you set your torque for install to the high end of the range (Say 90 ft/lbs for argument's sake) and then when you check them set to the low end of the range AND DON'T OVER TIGHTEN (say 80 ft/lbs here) , you shouldn't break the thread locking compound loose.
Another route is to get marking paint and put a stripe across the lug nut and over the stud. That way you will be able to tell if it is moving at a glance.
Originally Posted by Myrt
you guys with the high miles on the spidertrax, do you re-locktite each time you re-torque?
