1.5" Rear Coil Spacer? Who makes one?
I am thinking i want to do a coil spacer while im waiting for the 14b rear and all the setup in the rear.
But i want to pick the rear up a little bit while waiting.
Does anyone know who makes a 1.5" rear coil spacer?
Thanks
Thanks
I need a little more lift on my rear after the AEV rear bumper and spare tire carrier today and will check with Teraflex tomorrow. I think they make a lot of different sizes.
I talked to Teraflex today and figured it out. In my situation I need to raise both sides but also raise the passenger side an extra 1/2" to compensate for the added weight of the spare tire carrier.
Plan is order two 2" spacers. Install one on passenger side and retain factory isolator. Install the other on the drivers side and ditch the factory isolator. That should raise both sides and then rotate back to have level. Bingo.!
