1.5 or 2 inch lift?
Well don't get me wrong I also offroad but where I go it's not anything I can't handle I would just like to bump up a hair
You could install coil spacers on top of your coils. They're just a plasticy puck sorta like blocks on leaf springs. they are cheap, come in heights from 1/2" - 2 1/2" and keep the stock ride since your keeping the stock coils. You could get heavier stock coils off a 4 door and get around an inch. Or get something like this Teraflex 1351502 - TeraFlex 1.5" Performance Leveling Kit for 07-14 Jeep® Wrangler JK 2 Door - Quadratec for a small coil lift. Read through this for some insight https://www.jk-forum.com/forums/modi...17/#post211272
From: Hawai'i, Miami , FL, Alaska, Tennesse..S America
depends 2 door or jku 4 door.. ?
the 2 door 2" from old man emu is pretty good and awesome drive-ability and highway good for 100mph if you wrangler can actually get to that speed lol i think 4 doors run naturally lower, so you need a 3" or 4" to make it look like a 2" on a 2 door
I would agree on the comfort and ride of the OME lift but it is more like a 3" lift unless you are carrying a lot of weight. The HD coils will gain more like 3.25-3.5" The op is asking for a small 1.5"-2" lift.
Rancho 2'' Trail System, choice of shocks the RS5000 or the RS9000XL adjustable shock
2-in. SPORT SYSTEM
Fits up to 33-in. tires
Front coil springs
Rear coil spring spacer included
Upgraded front bump stop spacer
Uses O.E. pitman
RS5000™ or RS9000XL™ Rancho Shocks Included
Rear brake line drop brackets
Will not affect the Electronic Stability Control System
100-percent bolt-on system
Limited Lifetime Warranty on all components
Rancho Suspension: 2007 - 2013 Jeep JK Wrangler - 2 & 4 Door 4WD
2-in. SPORT SYSTEM
Front coil springs
Uses O.E. pitman
