1-3/4" Lift...shock extensions?
Would I need shock extensions or longer shocks with a 1-3/4" lift? I'm more than likely gonna be getting the Rough Country 1-3/4" lift, but it says nothing about extensions or longer shocks...I'm assuming it wouldn't hurt the stock (from a rubicon) shocks with just 1-3/4" of lift, just wanna make sure when I order it.
I just ordered the same lift, without new shocks. RC offers them as an option. I'm going to beat the stock shocks for a while. I've talked to others with the RC 1-3/4" lift with stock shocks and they are completely satisfied.
Yeah I kinda wanted to get the 2-1/2" RC lift with the 2.2 shocks, but I don't really need that much lift. The 1-3/4" will be good enough, especially with just the 32" tires...should make a big enough difference I think.
Thanks!
Thanks!
Absolutely. You'll gain some clearance underneath, your 32's will proportional and you probably won't experience any steering irregularities that are present with some of the 2.5 inches and over lifts.
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
How bout the brake lines? Would I need to do anything with those, like the relocation brackets or something? My only concern would be when the front sway bar is disconnected and at full flex.
