09 jk 3 inch lift ??????
ok guys and girls,,,,, got an 09 jk, with 33's and a teraflex 2.5 budget boost with tera shocks,,,,, plan on getting a set of 3 inch BDS springs to replace the budget boost pucks,,,,,, will i need to do anything else or just change out the springs??????? thanks for any help.....
The FAQ's are usually a good place to start.
This one:
Q: What are all the components that I will need with a 3" lift?
And perhaps this one:
Q: What is Caster? How much do I need?
This one:
next question,,,,, will an adjustable track bar on the front be worth the money? and with a 4 door will i need to do anything about the caster on the front,,,,, will i need adj. upper arms?
thanks again
thanks again
I used the Zone Offroad 3", which I hear is made by the same people that make the BDS, but cost less(not lifetime warr. like BDS). I just used the basic kit with no extras, worked great.
I originally ordered the new front track bar, but it was back ordered so I put in the lift without it. The centering was off by less than 1/4" if any at all, so I cancelled the track bar order.
Also, I did not use the control arm relocation spacers because they require a mod to the mount that can not be reversed.
The only issue I have had with the lift is that on an extreme off road bump the rear track bar relocation bracket dented the new rear shock, but just cosmetic.
-wwiifirearms
-wwiifirearms
