'07/Aftermarket Valve Stems
I use standard high pressure valves. I used to use steel inner mounts, but they tend to leak more than a pull-in rubber stem. Also, they don't flex at all, so if you catch them on something they can simply break-off.
The high-pressure valves aren't the best looking valves if you're looking for bling, but their large base (part that's inside the air chamber) makes them very hard to pull out. That's why they're high-pressure rated.
Here's what they look like.
http://www.myerstiresupply.com/pls/m...rt_id=kflf6443
