@#$% body lift!!!!
Old 01-20-2009, 04:19 PM
  #41
Will35's Avatar
I was the one that first did this and posted it as a fix (do a search for MORE body lift problem) and I can tell you I went back and measured the amount it will slide back and forth and it is 9/16'' so it is definately the difference on why some have no problems. I don't have shifting problems since doing this and it takes so little time I did it on my lunch break. I would recommend doing before you trim your boot to see if you still need to trim it. I would tell you though to loosen all the long body bolts including loosening the 2 nuts on the very front body mounts (by the front grill) that came with the kit to get full movement. Very simple and is better than boot cutting. Simple deal.
Old 01-20-2009, 04:38 PM
  #42
PONCH's Avatar
I still think your going to have to trim the shift boot. Reverse gave me a little issue today. Looks like the driver side might be a little bit further then the passenger. Might have to go through this again if it keeps up. It's hard to tell because its so cold or it could be me.
Old 02-02-2009, 09:42 AM
  #43
mike79's Avatar
I installed a 1" body lift yesterday, and I am having the same problems. I am going to try grinding some of the plastic down on the inner boot to see if that is it, but I think for me it is the outer boot putting pressure on the shifter. I have already cut out a good sized chunk of rubber out of the inner boot.
Quick Reply: @#$% body lift!!!!
