$2000 to play with. How to make the most of it.
If you ever drive at night or early in the morning then the BEST upgrade you can make for a DD is to replace the headlights and harness. Don't fall for the bulb or fixture replacements. The wiring is a large part of the problem.
Gussets are cheaper than repairing or replacing bent C's.
Recovery gear is cheaper than a tow truck.
Superchips is money well spent.$300
Winch would be good for you.$300 + a plate to mount it on your stubby
2.5 coil lift $450
tires? your choice determines price and then you're tapped out.
I got some black rocks with 265/75 Nitto terra grapplers I've been trying to sell for $500. IDK if you would be interested or how far a drive you are
2.5 coil lift $450
