WRITE-UP INDEX: The Quintessential Source for Do it Yourself Write-Ups
JK-Forum Founder
WHEELS & TIRES
PROJECT-JK.COM WRITE-UPS
• Spidertrax Wheel Spacer Installation Write-Up
• Pro Comp Xtreme Mud Terrain Tires & Pro Comp Series 8179 Black Powder Coat Wheels
• Hutchison Beadlock Installation Write-Up
• Steer Stop Adjustment
• Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
MEMBER WRITE-UPS
• Black Moabs
• Tire pressure deflator/inflator/pressure equallizer(2 tires at once)
• How To Make Center Caps
• Wheel Stud Replacement
MEMBER WRITE-UPS
• Black Moabs
JK-Forum Founder
OTHER ACCESSORIES
• Project-JK ARB High Output On-Board Air Compressor Under the Hood JK Installation Write-Up
• Project-JK COP4X4 Cargo Nack Installation Write-Up
• Project-JK Decal Application Write-Up
MEMBER WRITE-UPS
• Fire Extinguisher Install
• Cool keychain
• Cheap CO2 On-Board Air Solution
• DIY: On Board Air (Engine Bay Mounted)
MEMBER WRITE-UPS
• Cool keychain
JK-Forum Founder
MAINTENANCE & OPERATION
MAINTENANCE
• 42RLE Automatic Transmission Service Write-Up
• Bleeding Your Brakes
• Differential Fluid Change Write-Up
• NSG-370 Manual Transmission Service Write-Up
• NV-241 / NV-241OR Transfer Case Service Write-Up
• 3.8L Engine Oil Change Write-Up
• Rear Brake Pad Replacement
• Emergency/Parking Hand Brake Adjustment
• JK Torque Settings
OPERATION
• Project-JK Door Removal Write-Up
• Freedom Top Removal
• Opening Up the Sunrider Soft Top
• Lowering the Sunrider Soft Top
MEMBER WRITE-UPS
OPERATION
• Manual Swaybar Disconnect (non-Rubicon models)
MAINTENANCE
OPERATION
MEMBER WRITE-UPS
OPERATION
JK-Forum Founder
TROUBLESHOOTING & FIXES
TROUBLESHOOTING
• Technical Service Bulletin (TSB) & Recall Information
• Diagnostic Trouble Codes (DTC) How to Check Them & What They Mean
• Axle Breather Hose Extension Write-Up
MEMBER WRITE-UPS
FIXES
• D-Ring Silencers (Stop The Clank)
• Drilled the side view mirrors
• A 75 Cent solution to seatbelt flap!
• Hood lift fix
• Fixed my BAD soft top wind noise
• Tailgate shock project
• Woods Evap Canister Relocation Kit (illustrated)
• Woods hood shock kit install
• Trans cooler
• Transmission Cooler
• Rock Rail Trimming
TROUBLESHOOTING
MEMBER WRITE-UPS
FIXES
• Hood lift fix
• Trans cooler
