Wiring a 3rd Brake Light w/ Swingout
Old 11-21-2010 | 09:33 PM
JocKy's Avatar
Nice! Glad to help!
Old 12-11-2010 | 06:17 PM
mwbmorley's Avatar
Thanks for the detailed write up. It really helped me this weekend to have this on my iPad while working on the jk. Only problem i have left to solve is seating that piece of foam in the right spot. Any words of wisdom?
Old 12-12-2010 | 07:56 PM
JocKy's Avatar
If you pull it all the way out you will see the orientation that it goes with the hole in the tub. Sort of an oblong, boomerang, guitar pick shape. That's my only advice.
I only removed the foam to get my arm up inside of there.
Old 12-13-2010 | 05:22 PM
txJK2010's Avatar
Great write-up I just came inside frustrated with this same problem. I have the LoD tire carrier and just gave up for the night. Tackle this tomorrow!
Old 12-13-2010 | 08:01 PM
boots's Avatar
Nice job Jocky. Good to see you took the time and effort to make it work......
Old 12-15-2010 | 10:40 AM
scouter4life's Avatar
Lesson learned from a similar wiring I did a while back, running the wiring between the body and bumper is not a good idea. The body will move and flex differently than the bumper and if enough flexing occurs, it can damage/cut the wires.
You are better off to drill a small hole in the bumper and use a grommet to give it a clean look to run the wiring through.
Old 12-15-2010 | 04:25 PM
JocKy's Avatar
Great idea!
I will do this when I run my CB antenna and reroute the license plate.
Old 11-01-2023 | 08:13 PM
LMT_79's Avatar
Default Heyyy there… 👋
Originally Posted by revolucion!
DOOOOOOOOOOOOOOOOOOOOOOOOOOOOOD!!!!!!!!!
perfect timing! i was planning on re routing that wire (or just ditching the 3rd brake light). thanks for taking the time and sharing your install. this is exactly what i needed.
I’m only here to learn about this because, after 2 years of owning my Rubicon, I just got pulled over for not having a 3rd brake light. 😒 js…. Might wanna keep it. Lol
Old 11-02-2023 | 04:48 AM
resharp001's Avatar
Welcome to JKF. They certainly started cracking down on that in Texas a couple years ago. It used to be nbd but i think 2 years ago the very lax car inspection guy I go to said nope, they absolutely won't approve without 3rd brake light these days. I wonder what happens to stuff like this in 2025 when they stop requiring safety inspections due to the legislation recently passed.
Quick Reply: Wiring a 3rd Brake Light w/ Swingout
