Transmission Cooler
#521
I did mine over a year ago... but I was finally able to check the temp.
Just driving around my toen, the temp was between 120 to 135, very happy with that.
Also I replaced the OEM lines with AN6 connections (It ended up being refunded by Chrysler!) and it is absolutly dry.
#523
I recently noticed that the lines I cut for the new tranny cooler are fine but the remaining factory line is leaking/weeping. Its not a lot but its def something that I want to fix what do you guys think would be the best way of going about this? Its coming from the factory flange but I know that they aren't going to touch it at the dealership since I modified the rest of the system. Any ideas?
There is a factory recall on those lines. The addition should not automatically void you. I would press the issue a little with my dealer. Worst he can say is No!
Let us know how it turns out.
#524
I agree,but you can just about bet their going to say he caused it by disturbing the line when it was cut.
#525
#528
The dealer will see the line as having been hacked.
I'm pretty sure they have to turn in the parts replaced under warranty.
But then, we just never know how the dealer will react to things the owner does.
#529
im new to this forum had some questions regarding this
I have a traniee cooler in my jk am i suppose to have it on at all times? reason im asking my truck is a 08 with 25000 miles supercharged on 37 and I just blew my traniee.
#530
Sounds like the transmission couldn't take the supercharger.
