Transmission Cooler
Old 10-21-2011, 06:46 PM
  #511
ac1brooks's Avatar
I just installed my tranny cooler. Adavance auto parts for $54.00. Took about an hour. My trans temp went from an average of 195 degrees to 152 degrees. Huge difference & great write up.
Old 10-22-2011, 04:27 AM
  #512
MikekiM's Avatar
Are the benefits of the trans cooler limited to autos or would 6-speeds benefit as well?
Old 10-22-2011, 04:43 AM
  #513
ronjenx's Avatar
The 6 speed has no oil pump, no plumbing, and the fluid doesn't overheat.
Old 10-22-2011, 06:40 AM
  #514
MikekiM's Avatar
Yup... Just got out from under my JK and self-answered this. THX!
Old 11-04-2011, 06:42 PM
  #515
J-VET's Avatar
Followed the write up and all went great,
Just hasn't been hot enough to put it to the test.
Thanks
Old 11-05-2011, 09:55 AM
  #516
DGriz's Avatar
My B&M worked GREAT during my first big trip pulling a 19' trailer. Had a few climbs that tested the cooler and it didn't let me down. The gauge never got above 160 degrees, even when I forgot to take O/D off. DOH! When I realized it was on, I turned it off and the temp dropped right back down. Although 160 really isn't that hot so I was never in any danger. Big thumbs up to B&M
Old 11-06-2011, 02:49 PM
  #517
Rob 12B1P's Avatar
Thanks for the write up, installed mine today. I thought it odd that the B&M kit was so complete yet it was short two hose clamps. Regardless the install was easy thank to the write up.
Rob
Old 11-08-2011, 06:37 PM
  #518
mmcc's Avatar
I'm about to install a B&M supper cooler 70268 on my 2010 JKU... Question: has anyone has any pressure leaks at the connections over time?
Just checking before I cut?
Old 11-09-2011, 12:20 AM
  #519
Rhino64's Avatar
I had done this mod over 3 yrs ago and never had a leak. You should be fine.
Old 11-09-2011, 01:20 AM
  #520
fadeout's Avatar
I recently noticed that the lines I cut for the new tranny cooler are fine but the remaining factory line is leaking/weeping. Its not a lot but its def something that I want to fix what do you guys think would be the best way of going about this? Its coming from the factory flange but I know that they aren't going to touch it at the dealership since I modified the rest of the system. Any ideas?
Quick Reply: Transmission Cooler
