Transmission Cooler
Old 06-10-2011, 04:04 PM
  #441
icerk's Avatar
I was in 2wd for a while and then went into 4wd.
Old 06-10-2011, 04:11 PM
  #442
icerk's Avatar
If I decide to so the install will probably do a beer and pizza jeep party at the house to meet other jeepers in the area.
Old 06-10-2011, 04:19 PM
  #443
thunderstrike's Avatar
In 2 WD in rough terrain in climbing situation will shoot up tranny temp. If you stay in 4WD early on you will not have high temp issue.
Having a cooler will not help climbing 4-wheel trails in 2WD.
Old 06-10-2011, 04:26 PM
  #444
ronjenx's Avatar
Do you mean 4WD lo?
Old 06-10-2011, 04:31 PM
  #445
icerk's Avatar
I was in 4wd high.
Old 06-10-2011, 04:32 PM
  #446
icerk's Avatar
First vehicle I have owned that did not have a tran cooler
Old 06-10-2011, 04:41 PM
  #447
ronjenx's Avatar
Are you thinking the JK doesn't have one?
Old 06-10-2011, 05:11 PM
  #448
icerk's Avatar
If it does I haven't found it yet. Not that i have spent much tome under the hood. my tundra has a massive one in front of radiator with a fan.
Old 06-10-2011, 05:14 PM
  #449
ronjenx's Avatar
When you look through the grill slots, you can see the A/C condenser. It looks like a radiator. At the bottom of the A/C condenser is the transmission cooler. There are two lines hooked to it on the driver's side.
Although it's called a transmission cooler, it's too small, and mostly out of the air flow.
Old 06-10-2011, 05:17 PM
  #450
icerk's Avatar
Ok. Thanks for the info. Guess I need to open the hood more often and take a look. I like how on the tundra it's up front.
Quick Reply: Transmission Cooler
