Transmission Cooler
Old 03-21-2011, 02:17 PM
  #361
Thorty's Avatar
I installed this cooler two weeks ago:
Thorty
Old 03-22-2011, 11:50 AM
  #362
EarlyJk's Avatar
Originally Posted by mijku
got any part numbers for the couplers you used?
Here are the part #s.
ID:	140737   Click image for larger version
Old 03-22-2011, 12:09 PM
  #363
mijku's Avatar
thanks for posting them up
Old 03-24-2011, 08:39 AM
  #364
Pluke the 2's Avatar
make sure you guys check up on these connections because mine is leaking. now i got to pull off the grill and retighten all the hose clamps and it sprayed my engine full of tranny fluid and i got to power wash the engine and replace my damn belt.
Old 03-24-2011, 08:54 AM
  #365
PagosaGlen's Avatar
I have my cooler coming now. What do I need to look out for when making the attachments? Did you make a mistake or did it have something to do with the fittings?
Old 03-24-2011, 09:27 AM
  #366
nah, no mistakes. they just came loose. so i got to retighten them up again.
they came loose at the connection where the hose goes into the cooler nipples...
Old 03-24-2011, 12:03 PM
  #367
Rhino64's Avatar
Originally Posted by WantAunLimiteD
is anyone adding a temp gauge? im wondering if i should go with a cooler with a fan for when im wheeling and theres no airflow.
You need a fan,if you use your jeep off road. On a warm day your Jeep will will still reach temps above 200* +.
Old 03-24-2011, 04:23 PM
  #368
adamisadam's Avatar
Due to the heating & cooling, you need to tighten the house clamps after a few days of use, then you'll be good to go.
You do not NEED a cooler with a fan because the oem fan will pull air through the cooler. But extra fans can never hurt. Or, you could add an override switch to control the oem fan.
When I was done installing mine I got the jk hot enough that the fan came on at the low speed (there are two fan speeds), and man does that thing move air. Then the other jk got his fan to come on at high speed, wow!
Old 03-24-2011, 04:36 PM
  #369
Rhino64's Avatar
I've already experienced it without a fan and the cooling fan does very little good when it comes to cooling the auxiliary cooler. I'm not making these temps up there monitored with a aeroforce gauage and it's accurate. If you don't mind your tyranny exceeding 200+ deg's than you don't need a fan.
Old 03-24-2011, 04:43 PM
  #370
adamisadam's Avatar
Where is your gauge sensor located?
I think we would benefit greatly by using our oem fans. I successfully did this years ago with one of my motorcycles. I'm just wary of tapping into the very computer controlled jk system. But ideally, I'd be able to turn on or off my fan while allowing it to also work like stock. I would turn it on during long, slow crawls in extreme heat. I'd turn it off before entering a water crossing.
Quick Reply: Transmission Cooler
