Transmission Cooler
Old 03-20-2011, 09:07 AM
  #351
EarlyJk's Avatar
Heres a pic
Old 03-20-2011, 09:47 AM
  #352
funtimes's Avatar
Ya but reading through the threads "racinjimy" did this and he never mentioned having to flair it....I wonder if it would be ok to crimp down without a flair? Don't want to buy a flairing tool for 1 job and never use it again..
Old 03-20-2011, 09:51 AM
  #353
EarlyJk's Avatar
Wouldnt chance it, when it easy enough to flare it. If you just try an clamp it without flaring an using the Aeroquip Connectors I believe it will leak after time. If you are seriously debating cutting off the factory crimp fittings then you should def. go the extra step an flare.
Old 03-20-2011, 09:53 AM
  #354
TheQuiet1's Avatar
I didn't flare mine and I haven't had any problems. That's not to say that I won't, but so far so good. I did use fuel line clamps on mine where the new rubber lines connect to the factory steel lines just as a precaution though.
  #355
EarlyJk's Avatar
Go to an auto parts store that lets you borrow tools for free. Advanced Auto Parts around here does that. Use a 3/8s flare.
Old 03-20-2011, 04:28 PM
  #356
onebadrc's Avatar
I installed the 70266 today. I deliver mail so I'm idling or crawling all day. Thanks for the write up Paratus13!
Old 03-20-2011, 04:57 PM
  #357
mijku's Avatar
Originally Posted by EarlyJk
Heres a pic
got any part numbers for the couplers you used?
Old 03-20-2011, 07:48 PM
  #358
yomondo's Avatar
If you have an AutoZone near you, try them too. I borrowed a flaring tool for free from them when I had to repair a broken hard brake line.
Old 03-21-2011, 05:22 AM
  #359
EarlyJk's Avatar
Ill list the part #s for you.
Old 03-21-2011, 01:55 PM
  #360
Dronac's Avatar
Just installed a cooler this last weekend. It was easier then I expected it to be.
Quick Reply: Transmission Cooler
