Transmission Cooler
#282
I like the idea of the this type of connection, but do you think it would have been beneficial to have left the little ridges (not the lip at the end) in place for some extra grip on the hose? It is somewhat hard to tell if there is some grip factor there from the pictures.
#283
I was trying to do what you are thinking and leave the hard line intact but it was just unnecessary fiddling, cut them off it takes 5 minutes and be done with it...........
#284
Finally got this done....
Finally got around to doing this mod...thanks paratus13.
One quick note... I did remove the coolant overflow to give me more room to work with through the top, it simply slides off and back on...2 seconds...the extra room helped.
I drilled holes for my brackets instead of attaching them to the rubber pieces (not for sure if paratus13 did this or not)
Thanks again!
Thanks again!
#285
I got the HOT OIL buzz and light show twice just out wheeling, I am going out this weekend to buy the stuff to do this mod. Thanks for for all good advice folks.
#286
Thinking about doing this mod.
What is the most updated install info for the B&M Cooler (#70268). Is the original write up still current or have trial and error updates been made?
Also,
Those that have painted their brackets and hose clamps, what type of paint did you use? Should high temp paint be used? (I'm a novice, sorry).
Also,
#287
Also,
Also,
1) The direction the cooler is mounted (inlet/outlet's up or on the side).
2) How the lines are routed (Direction wise).
3) Wether or not you use the brass fittings supplied by B&M to tap into the factory rubber line, or you install straight onto the metal line (Involves removing the OEM rubber line completely).
4) Lastly... which cooler you choose to use.
All variations seem to work. You can see my install, post 258 on page 26. Only thing not visible, due to not taking a photo, was I removed the factory rubber trans hose and installed the B&M lines straight onto the factory metal trans line. I'm very happy with my install and it should protect my transmission for the rest of its life.
This thread was very usefull to me and I thank the OP and everyone who contributed
#289
Grayghost
Did they tell you the BTU rating
Any Pictures
Thanks
Took JK into off-road shop for a Trans cooler, thought it would be a small one. When I got it back the cooler is approximately 7 1/2"X22"x1" (manufactured by LONG). This seems big, but the shop foreman said this is what they recommend for Unlimited JKs. He assured me it won't affect the motor cooling. What do you think??
Any Pictures
Thanks
#290
Did this mod yesterday. Easy! I've had that "hot oil" light come on and it ain't fun. Great mod! Thanks for the detailed write up.
