Transmission Cooler
Old 08-31-2010, 03:46 AM
  #271
racinjimy's Avatar
Originally Posted by Endo
Is the factory metal line flared on the ends? Is is it just straight metal tubing?
I went through the trouble of cutting off the factory crimp with a dremel, it took me about an hour to do both
after I attached the 3/8 hose, it leaked like mad!
if you look at the hard line under the hose, it is textured to match the crimp (but not flared)
save yourself the time and just cut the hard line, which is what I did in the end and it took 5 minutes
Old 08-31-2010, 03:12 PM
  #272
Camojeep's Avatar
Default cooler
Thanks , that info helped.
Old 09-02-2010, 07:21 AM
  #273
COL V's Avatar
Default Got Enough
Originally Posted by hevnbnd
I bought 5ft extra. 4 might have done it but it would have been close.
Thanks for your post. Since I purchased here in England, I got 2 meters of hose. Hedging for more like you recommended.
Old 09-02-2010, 07:26 AM
  #274
COL V's Avatar
Default Thanks
It does come with the brackets you will need.
You were spot on. I even wrote to the customer service folks at Summit to ask what the B&M 70264 came with. Thier resonse was:
"The BMM-70268 includes the cooler, pull through radiator mounting straps, brass hose barb fittings, and 3/8" rubber line.... Hose does come with clamps. There are no mounting brackets"
Was please to unpack today and find all the accssories needed, which would have been a bit difficult to find here. My trust level with the Summit representative is low.
r/ Mike
Old 09-04-2010, 06:14 PM
  #275
GutlessPhred's Avatar
thanks so much for the write-up, sure made it easy. got mine all installed.
Old 09-05-2010, 05:20 AM
  #276
jeepoholic's Avatar
A must do if your running 35's and go wheeling a bunch!
Old 09-05-2010, 06:17 AM
  #277
scootrrydr's Avatar
If it's so easy....come over and do mine!
Old 09-05-2010, 06:55 AM
  #278
racinjimy's Avatar
Default picture of the ends of the hard lines
I did my install last weekend. here is a picture of the end of the hard lines that I cut off. I could not get the 3/8 transmission line to not leak without cutting the ends off
Old 09-05-2010, 06:59 AM
  #279
racinjimy's Avatar
Default pic of install
I routed my lines differently, I routed one line to the right and the other to the left, I use 4 feet of extra 3/8 transmission line from Vatozone
Old 09-05-2010, 12:37 PM
  #280
tls001's Avatar
Finally did this mod last week, using this write up it was very easy and didn't take long at all. I mounted mine closer ( 1/2 to 3/4 inch space between cooler and condensor) and you can feel the air being pulled through it at idle with the fan running. Also routed my hoses a little differently to hid them a little better. Thanks for great write up.
Quick Reply: Transmission Cooler
