Transmission Cooler
Old 08-25-2010, 01:45 AM
  #261
COL V's Avatar
Originally Posted by hevnbnd
Attached some pics of mine. I went with the inlets up. Seemed cleaner, however it took an extra 4 feet of line and a lot more time running the hoses. I also cut off the old metal and attached directly to the metal trans lines. FYI I got the BMM-70264
Thinking about doing this mod, but have question about hose length required. How much hose was provided in the B&M-70264, and how much did you have to purchase additionally to make the runs you did?
Mike
Old 08-25-2010, 03:09 AM
  #262
Endo's Avatar
Is the factory metal line flared on the ends? Is is it just straight metal tubing?
Old 08-25-2010, 07:35 AM
  #263
TheQuiet1's Avatar
Mike
70264 & 70268 come with 4ft of hose. It requires an additional 4ft to route the lines this way. The additional hose is about $2 a foot from the local auto parts shop.
Old 08-25-2010, 07:41 AM
  #264
TheQuiet1's Avatar
Under the factory crimp connector/ferrules the metal line wasn't flared on mine, just straight.
Old 08-27-2010, 01:00 AM
  #265
COL V's Avatar
Default One More Question
Question to one of you that have installed the B&M 70264 with the brackets. Ordered the cooler, but Summit Racing indicates kit does not come with brackets & hardware (just the push through ties). So I need info on size of brackets to fab some. Going to do this fabrication for mod in Stuttgart, Germany, so no need to send me to Home Depot or like place.
Thanks!
Mike
Old 08-30-2010, 04:10 AM
  #266
WhiskyPirate's Avatar
Did this install yesterday and was super easy. Took about 2 hours since I take my time with everything. Since I had some extra rubber drain hose lying around from another project I decided to wrap the cooler lines for the areas making contact with the frame and condenser just to prevent chafing. May be overkill, but figured it couldn't hurt.
ID:	84831   Click image for larger version
Old 08-30-2010, 05:33 AM
  #267
wallawallaron's Avatar
Post
I like it good idea and another free mod.
Old 08-30-2010, 02:01 PM
  #268
Camojeep's Avatar
Default Big Transmission Cooler
Took JK into off-road shop for a Trans cooler, thought it would be a small one. When I got it back the cooler is approximately 7 1/2"X22"x1" (manufactured by LONG). This seems big, but the shop foreman said this is what they recommend for Unlimited JKs. He assured me it won't affect the motor cooling. What do you think??
Old 08-30-2010, 03:23 PM
  #269
915RUBICON's Avatar
I did mine over the weekend, Works great I went with the Torqflo Super cool from VATOZONE...LOL. I went with the big one. It is 11" X 11 3/8" and I also went with an 8" E-fan with an in-line temp switch that kicks it on @ 185 deg. and off at 170 deg. It works great I went out wheeling @ the sand dunes with it 99 DEG OUTSIDE and the outside of the tranny pan was sitting right about 195 with the fan running. (used a temp gun). NOW ANOTHER PROBLEM........ NOW the water temp was INCREASING....WTF?? oh well I am going to have to keep an eye on it and see what the next step will be, unless someone out there has any suggestions?
ID:	84999   Click image for larger version
ID:	85000   Click image for larger version
ID:	85002   Click image for larger version
Old 08-30-2010, 06:56 PM
  #270
Sounds like that cooler setup may block a little too much airflow to the radiator. Since it does have its own fan you could mount it a bit more off the side of something.
Quick Reply: Transmission Cooler
