Transmission Cooler
#242
just to update mine-- I was able to cut the ferrules off & go straight to the OEM lines. I just made two cuts with a cut-off wheel through the aluminum ferrules and then pried them off with diagonal cutters. I like the idea of less hoseclamps & no restrictive barb unions.
Why not cut with a hack saw? can't get in there?
#243
I did this mod this past weekend. Thanks for the great write up all - it was very helpful. I ended up using the two rods to secure the top of the cooler to the oem tabs.
#245
I killed 2 birds with 1 stone. I added the cooler, and I did the grill mod at the same time. I drilled and tapped the holes for the cooler into the front of the Jeep, and used a bedliner spray for the brackets that held the cooler. Pretty easy mod that will pay off in the long run.
#246
I'm not familiar with the "grill mod" and searching is bringing back lots if different results. What mod ?
#248
#250
After getting the "HOT OIL" warning several times while driving up a PAVED road, my wife basically ordered me to install one of these. I guess she got a little scared that the tranny fluid would ignite and burn the Jeep down. I tried to tell her that was the worst case scenerio, but figured I'd just nod and order the kit. I've been wanting it for a while now.
Ordered the B&M kit from Amazon.com for $53 shipped.
