Transmission Cooler
#211
Great write up. I used this to do my cooler install. I ended up routing one of my hoses a bit different but other than that this was a great guide to get it done. Thanks!! JOE>
#213
#214
It will self purge. Mine took about 3/4 of a quart to get to the bottom of the 2 full hot holes on the dip stick.
#215
I had to add 1/2 a quart aas well. Did anyone else use different hose than what came with their kit? I found alot nicer hose at the auto parts store than what was with mine. They had high pressure tranny hose, it was quite a bit stiffer and harder to route but it will fight collapsing more. Just curious. JOE>
#218
Anyone put in a temp gauge?
#219
I finally added a cooler to mine. I am going to be towing a small trailer for camping so i did not want to take any chances of burning up my transmission over time.
![Bleh](https://www.jk-forum.com/forums/images/smilies/bleh.gif)
#220
Thanks for the write up. I just ordered in a couple 70264 coolers (it's the thicker version)
I'll be putting them in on Friday probably.
Has anyone bothered to install a temp guage on the transmission fluid output line ? In my opinion, THIS is the important spot to have a guage, as it's going to show the actual transmission fluid temp, not the temp after it's been passed through a cooler.
