Transmission Cooler
#141
Where on dipstick is full???
K quick question, how do I know when I have the right ammount of fluid in? My dipstick does not have a full mark, just and 'ADD' 'COLD' and 'HOT' but no FULL. Dont want to underfill and CERTAINLY dont want to overfill.
#144
The appropriate way to check it....Get your jeep up to running temp, put her in park, then run through each gear all the way down to 1 (or 2, cannot remember the lowest gear?), then back up to park. Leave the jeep running, get out and ck your fluid. Should be right on the HOT mark.
#147
The appropriate way to check it....Get your jeep up to running temp, put her in park, then run through each gear all the way down to 1 (or 2, cannot remember the lowest gear?), then back up to park. Turn off the jeep, get out and ck your fluid. Should be right on the HOT mark.
#148
Glad you caught that. I was trying to remember, it's been a while. Thanks!!!
#149
In the tranny service write up on the Project-JK site, it states:
22. Pull out your transmission dipstick and check its fluid level which should be about 1/8″ below the lowest mark on the dip stick. If necessary, add more fluid as needed and recheck the fluid level after your transmission has reached normal operating temperature, approximately 180°F.
what does it mean 1/8" below the lowest mark??? Where exacally do I want the level, there are 4 holes , 1 at add, 1 at cold, and 2 at hot.
#150
22. Pull out your transmission dipstick and check it’s fluid level which should be about 1/8″ below the lowest mark on the dip stick. If necessary, add more fluid as needed and recheck the fluid level after your transmission has reached normal operating temperature, approximately 180°F.
It then tells you to recheck after the tranny warms up to normal operating temp. Then it should be near the "HOT" mark.
