Transmission Cooler
#131
#133
IMO..The Auto's should have come with a Transmission cooler from the factory. I will be installing one this weekend. Due to larger tires coming next week. Still on 3.73 gears right now. Will switch out to 5.13's in a month or two. Warranty void or not it's getting a cooler.
#134
of course, there's the idea that a tranny cooler should help PREVENT a warranty claim altogether! (and a potential breakdown!)
I'm just debating mounting it close or far from existing radiator.
Advantage of close: you get cooling effect from electric fan which is critical when trail crawling at low speed.
Disadvantage of close: might be hard to clean mud from in between the coolers.
#136
My Jeep is in the hospital right now due to no tranny cooler. The dealership said nothing of why the thing is shifting like crazy as I drive and has nothing to say about the BURNT ATF either! Except of course that it'll be $200 for a tranny service. So I did a little research earlier and found that Chrysler will be issuing a recall on Wranglers with auto trannys 07-08 due to danger of ATF BOILING over and causing vehicle fire!!! Solution: equip the vehicle with a warning on the cluster that says hot oil...... sounds like a good fix to me!?!?
#137
Thanks for the write-up. I finished the install and I couldn't have done it without this thread.
Thanks to All
Francisco Lopez
Thanks to All
Francisco Lopez
#138
ok..i got the install of the actual cooler, but if i wanted to hook up a temp gague, HOW does it read the temp?does the gague have a probe that pokes into a hose? or does it read it electocnically?
#139
Or, you could install a gauge with a temp probe in the transmission pan.
#140
Just got done with mine, thanks for the write up. I just used the plastic zip-ties because i didnt feel like drilling and painting etc. I like the clean look it has with the zip ties. Doubt the ammout of mudding i do that I should have any problem with mud getting in between there.
