TPMS sensor removal
TPMS sensor removal
Is there a write up on how to remove a tire pressure sensor or does someone know how to remove them? Going to get my wheels powder coated.
If its a 12, you will need a torx bit, I believe t15, and a valve stem puller. Unscrew the sensor from the steml and pull the plastic part away from the stem. Then pull the stem through the rim with the puller. Just make sure when you reinstall the TPMS you do not over tighten the screw. You just need it snug, they break easily. I changed tires all through college.
