Sway bar disco motor
Old 12-14-2006, 05:53 AM
joss097's Avatar
Default Sway bar disco motor
I was looking for a thread on rotating the disconnect motor for more clearance but cannot find it. Do anyone have info on doing that. I remember that it can be done on PowerWagon and want to know if it's possible with the JK.
Old 12-14-2006, 05:59 AM
JK-Forum Founder
wayoflife's Avatar
The only JK I have seen this done on is Kilby's. If memory serves me right, it required some fabing of a bracket and rubber hanger. However, there was no real explination beyond that provided. Sorry.
ID:	226799   Click image for larger version
ID:	226800   Click image for larger version
ID:	226801   Click image for larger version
ID:	226802   Click image for larger version
ID:	226804   Click image for larger version
ID:	226806   Click image for larger version
Old 12-14-2006, 07:21 AM
joss097's Avatar
So we can assume that you will surely find something when you got yours! Maybe someone at Kilby's (or someone else) have some idea of producing a kit for this.
ID:	227762   Click image for larger version
ID:	227763   Click image for larger version
ID:	227764   Click image for larger version
ID:	227765   Click image for larger version
ID:	283534   Click image for larger version
ID:	283535   Click image for larger version
ID:	283536   Click image for larger version
ID:	283537   Click image for larger version
Old 12-14-2006, 07:39 AM
JK-Forum Founder
wayoflife's Avatar
Kilby will be providing a kit that is included with their new front bumper which also comes with a skid plate to protect it. The only thing is, you will have to cut off the lower cross member in order to install his bumper if memory serves me right.
ID:	228052   Click image for larger version
ID:	228053   Click image for larger version
ID:	228054   Click image for larger version
ID:	228055   Click image for larger version
Old 12-14-2006, 09:25 AM
cwalker's Avatar
Default How to rotate your swaybar disconnect
It can be rotated up and out of the way by relocating a bolt hole. It doesn't require a new bracket either.
Here's how:
You'll need the following:
16mm socket (for swaybar bushings bolts)
15mm wrench (for disco unit hanger bolt)
a 'new' bolt: 12mm or 1/2" x 5" long (min length would be 4.5")
a drill and tap to match your bolt
1. Turn wheels to the right.
2. Located hole to be drilled and tapped. (see pic 1.)
3. Drill and tap hole for 12mm or 1/2" bolt. (I used the larger 1/2" and it worked fine.)
4. Remove the bolt that attaches the disconnect unit to the rubber hanger. (see pic 2.)
5. Remove the 4 bolts that hold the swaybar to the frame. (see pic 3.)
6. Unplug the Swaybar disconnect wiring hardness. (The large one that connects to the sway disco unit.) and unclip the harness wires from the zip-tie.
7. Push swaybar towards the rear of the Jeep. (you don't have to disconnect it from the axle.)
8. Rotate the disconnect unit forward approx 90degs.
9. Replace rubber hanger bolt with new bolt, and attach to new hole. (minimum bolt length = 4.5") (see pics 4 and 5.)
10. Reconnect swaybar to frame.
11. Reconnect disco unit wiring harness.
Notes:
-The rubber hanger stud that extends from the swaybar bushing bracket can be bent for a proper fit once the unit is in its new location.
-I used a 1/2x4.5" bolt, which is why the hanger bushing is slightly angled... a 5" bolt would be the correct length to use.
-A winch that sits between the frame rails may interfere with the rotated unit. (There's still lots of clearance for a winch, but who knows. )
Sorry for the terrible pics... camera phone.
SEE POST BELOW FOR BFORE AND AFTER PICS
Name:	1. Before clearance - hole drilled.jpg
ID:	254   Click image for larger version
Name:	2. Bolt removal.jpg
ID:	255   Click image for larger version
Name:	3. Unbolted Swaybar.jpg
ID:	256   Click image for larger version
Name:	4. Bolts.jpg
ID:	257   Click image for larger version
Name:	5. After closeup.jpg
Old 12-14-2006, 09:47 AM
cab76's Avatar
Originally Posted by cwalker
It can be rotated up and out of the way by relocating a bolt hole. It doesn't require a new bracket either. Sorry no pics right now, I might be able to post some this weekend... if there's enough interest.
The only thing you'll need is a longer bolt (to replace the one that goes thru the rubber hanger) and a drill and tap to match the tread for that bolt. (and tools, of course.)
1. Unbolt 4 bolts from swaybar bushings and let it drop down. (the ones connecting it to the frame.)
2. Disconnect plastic clip securing wiring to disco unit. (just the one holding the wires, not the main plug)
3. Remove the bolt that goes thru the rubber hanger and screws into the disco.
4. Rotate disco unit towards the front of the Jeep to locate hole to be drilled.
(there is already a tab on the disco unit with a cast hole that lines up with the rubber hanger bolt hole when rotated. It's obvious which one it is... maybe DC engineers already planned on using the hole for this reason??)
5. Rotate back down to drill and tap hole in housing.
6. Rotate back up and secure in place using longer bolt.
7. Secure wiring.
8. Rebolt swaybar to frame.
I had the bumper off when I did this, and have since moved it back to the stock location to fit a winch between the frame rails.
Please post pics! Relocating up is a great alternative to a skid at this location, in my opinion.
ID:	229505   Click image for larger version
Old 12-14-2006, 05:57 PM
joss097's Avatar
So you cannot put the winch betwwen the frame with the disco in the up position? Too bad if it's that
Post pics please
Old 12-14-2006, 07:06 PM
cwalker's Avatar
Please see edited post above for "how to".
Here are a few extra before and after pics.
Post pics please
There's lots of clearance even when it's rotated, but it prob just depends on which bumper you choose.
ID:	259   Click image for larger version
Name:	Before closeup.jpg
ID:	260   Click image for larger version
ID:	261   Click image for larger version
Name:	After clearance 1.jpg
ID:	262   Click image for larger version
Name:	After clearance 2.jpg
ID:	236895   Click image for larger version
ID:	236896   Click image for larger version
ID:	236897   Click image for larger version
ID:	236898   Click image for larger version
ID:	236900   Click image for larger version
ID:	236901   Click image for larger version
ID:	236902   Click image for larger version
ID:	236903   Click image for larger version
ID:	236905   Click image for larger version
ID:	236906   Click image for larger version
ID:	236907   Click image for larger version
ID:	236908   Click image for larger version
ID:	236910   Click image for larger version
ID:	236911   Click image for larger version
ID:	236912   Click image for larger version
ID:	236913   Click image for larger version
ID:	236915   Click image for larger version
ID:	236916   Click image for larger version
ID:	236917   Click image for larger version
Old 12-15-2006, 09:12 AM
Quebec4x4's Avatar
Remove it, remove crossmember ... and put Anti-rock !!
ID:	242212   Click image for larger version
ID:	242213   Click image for larger version
ID:	242214   Click image for larger version
ID:	242215   Click image for larger version
ID:	242217   Click image for larger version
ID:	242218   Click image for larger version
ID:	242219   Click image for larger version
ID:	242220   Click image for larger version
ID:	242222   Click image for larger version
ID:	242223   Click image for larger version
ID:	242224   Click image for larger version
ID:	242225   Click image for larger version
ID:	242227   Click image for larger version
ID:	242228   Click image for larger version
Old 12-15-2006, 09:26 AM
cwalker's Avatar
Originally Posted by BeerMonkey
awesome. now i need to figure out what to tell the wife about me taking off the bumper already. not to get to off topic but whats the blue thing in the background in the last pic?
Yeah, I've been driving around without a bumper for the last few weeks. My wife has just gotten used to it. I think the JK's look better without a front bumper, as opposed to the stock piece. imo
The vehicle in the back is a Terracruzer. (feel free to delete this Eddie, if I crossed a line in saying that... don't think I did.)
ID:	294453   Click image for larger version
ID:	294454   Click image for larger version
ID:	294455   Click image for larger version
ID:	294456   Click image for larger version
Quick Reply: Sway bar disco motor
