Spray in Liner - UPOL Raptor Tintable: Deep Water Blue
Old 02-11-2011 | 09:20 AM
  #51
dads jk's Avatar
Default Looks awesome
I am probably going to do this when the carpet gets beyond cleaning.
Old 02-11-2011 | 11:19 AM
  #52
Hook-Em's Avatar
I've had this item on my mod list for a while. I really liked the idea of paint matching the liner, but as worried how it might turn out. Your's looks awesome. That settles it. I'm going paint matched for sure now. I like the idea of doing the gate too.
Lining the top rail is an idea I had after removing the hard top the first time. That area takes a lot of punishment installing and removing the top. Have you developed any leaking/sealing issues since lining your rail?
Old 02-11-2011 | 09:03 PM
  #53
mark9998's Avatar
Originally Posted by DCJEEP
What's it like in the winter? Did it change the interior temp at all?
No there is no change in temp. It may be just a little louder than before, but really not much of a difference that I could tell from when I first took the carpet out
Old 02-11-2011 | 09:05 PM
  #54
mark9998's Avatar
No issues with any leaking or sealing with the top rails lined also, at least not that I have seen.
Old 02-11-2011 | 09:27 PM
  #55
Sapper12b's Avatar
Man I would love to do something like this but that is one of the downsides of living in a apartment. What kind of paint sprayer and air compressor did you use
Old 02-12-2011 | 08:48 AM
  #56
Hook-Em's Avatar
What is the thickness of the coating on the top rails? Sorry for asking so many questions it's just that once I make the jump to doing the rails, it's no turning back.
Thanks and cheers!
Old 02-12-2011 | 09:20 AM
  #57
GreenJK07's Avatar
I live in an apartment too, except I have a garage I used to do my work in my parking spot before I moved where I live now. I met alot of girls and friends Workin on my jeep in the parking lot! Not a bad idea...
Old 02-12-2011 | 01:04 PM
  #58
rexicon's Avatar
Thanks and cheers!
I've got at least a 1/4" of rhino lining on the tops of my rails and no probs with the hard top.
Old 02-12-2011 | 07:52 PM
  #59
mark9998's Avatar
The UPOL Raptor kit comes with its own sprayer, and you only need about 50psi to the gun. I used the compressor at my dads shop which is a pretty big compressor, but any compressor that puts out at least 50psi would do the job fine
Old 02-12-2011 | 07:54 PM
  #60
mark9998's Avatar
Thanks and cheers!
No problem at all on the questions. Im actually not for sure how thick the top rails are. I hit them quite a few times and tried to get a really thick coat, as I also did on the floorboards where most of the wear and tear will be. I havent actually measured it but I dont think mine is 1/4" like REXICON mentioned his Rhino line is
