Spray in Liner - UPOL Raptor Tintable: Deep Water Blue
#41
You have to buy the UPOL tintable kit first of all, the goop in the bottles is white rather than black in the standard black kit. Then I just went to a local auto parts store and gave them the factory paint code that the dealership gave me and they mixed me up a can of it. When you are ready to do the actual spray, you just mix the hardner and 10% paint (I ended up using 75ml of paint with each UPOL bottle) all in the UPOL bottle and shake it up really good for a couple minutes and you are ready to spray
#43
Your liner looks great!! I have product and i am getting ready to spray in next week or so. I have a couple of questions about tint. your 10% paint...Did you use a stright DIY color or just a DIY/base mix which you then mixed with Raptor base? Also the blue color you used, how acturate was it to the color you wanted? Did the raptor base alter the color at all? Any guidence would be great! I'm looking to do Sandstone/tan color and i'm just trying to get it right! Thanks again!
Good Luck, you will be surprised how easy it is!
#44
It took WAY too long doing it the way I did it with hammer and screwdriver. If I was to do it all over again I would of invested in or borrowed someones air chisel to speed up the process. I would definitely take the extra time to get that sound deadening goop out some how though, it looks so much better with it gone.
#46
Hope it looks as good as yours!
#48
Probably, I used a grinder to grind off a few of the studs that were under the seats and in the back, but I found it is really easy to grind right into the tub, which is not all that thick. I guess if you were really careful and good with a grinder Im sure it would work. Ive read some other posts where guys used air chisels and even cut through the tub with those by accident
#49
But I would say - skip that also. I didn't get the chance to try it until it was almost all gone, but when I hosed the chunks out and let it dry for a bit the remaining caulk in there was very soft instead of rock hard. I would try scoring the general areas with the hammer and screwdriver, through the paint is all - hose it with water a few times, and the caulking should be so soft it is easy.
Great job btw
