Spray in Liner - UPOL Raptor Tintable: Deep Water Blue
That looks really good! Congrats!! I like the color matched liner a lot, I don't have to worry about that when I finally decide I have the funds to this because my jeep is BLACK! Good job, Looks Great!! Ilike that you sprayed the trunk cove too!
Resistance is Futile
In a thread on electrical issues,someone mentioned that the electronics in the JK's are very sensitive to voltage/resistance;would adding splices and lengthening the harness cause an issue,or is the change too trivial to matter ? I realize tow harnesses add to this,but they are "designed" into the wiring loads..Thanks
Final Pics with Interior Installed
Here are some final pics with everything put back together. I forgot to take a picture before I put the hardtop back on, but I did the top rail as well as mine was already getting scratched from running the softtop in the summer. It turned out really good, and the hardtop seems to seal fine to it as I have not noticed any more noise than before.
I guess the big test will be how it holds up over time. Ill update in about 6months and let you know how it seems to be holding up. I can see how this stuff can get addicting. I think this summer once the hardtop comes off that interior white is going to end up blue.....
