Spray in Liner - UPOL Raptor Tintable: Deep Water Blue
#151
Does anyone have any pictures of this being sprayed over the sound deadening goop? I'm considering leaving it in and I'm thinking that it being all black, that it might not stand out that much.
#152
Ive seen pictures of it on other threads and my personal opinion is it looks like crap, even when black. If you are going to take the time to do the liner I would take the little bit of extra time and get the goop up, but thats just my personal opinion
#153
#154
I started the process of removing the sound deadening goop and found a process that is working pretty good. I took up the passenger front in about 15 minutes. I used a needle gun at a low angle and it came right up and then sanded with a hand sander and primed with paint. All said and done in about 25 minutes.
I just did the rear passenger areas and was done in an hour with everything.
#157
#158
I did this with Black last year and Im thinking of color matching my kids Island Edition.
How is the color holding up? any fade?
When you did the rear hatch you left all the carpet on? or did you remove it?
#160
They are some times called christmas tree push rivets/pins. I found some replacement ones at lowes in the bolts section. It was in a pull out drawer called automotive. They were for another make of car so there not identical and a bit shiny. They also sell them at auto stores. If your stupid rich you can get them at the dealers service department for about $3 a piece.
