Solid Diff Cover Install
Old 03-11-2008, 03:17 PM
  #21
tkob1060's Avatar
Location: Hangin in the sunshine state....staging forum..
Originally Posted by ronjenx
The fill plugs look a lot higher than the stock cover fill plugs. If you are supposed to check level and fill to the bottom of the fill hole on the stock covers, how do you do that on the "SOLID" covers?
Hey Ron, you dont fill them to the hole on the Solid covers, here are the amounts each axle takes on this link....if you over fill it will come out the breather tubes an I've had it make the pinion seal leak also after the shop filled it to the hole
Old 03-11-2008, 03:39 PM
  #22
MikeReo's Avatar
The link didnt show
Old 03-11-2008, 03:58 PM
  #23
tkob1060's Avatar
oops sorry about that
https://www.jk-forum.com/forums/show...le+leak&page=2
Old 03-11-2008, 04:23 PM
  #24
ronjenx's Avatar
Thanks. I went to the link.
But, it makes me wonder why they did not put the hole at the correct level.
Old 03-11-2008, 05:18 PM
  #25
tkob1060's Avatar
obviously you didnt read the entire post, see # 9
Old 03-11-2008, 05:53 PM
  #26
ronjenx's Avatar
Busted! I quit reading when I found the answer to my original question. There was some potentially bad advice in that thread, though.
Old 09-11-2008, 06:38 AM
  #27
easttnruby's Avatar
So where are yall getting the h-14 hex bit? cant seem to find them anywhere.
Old 09-11-2008, 07:23 AM
  #28
fish's Avatar
Location: Apple Valley, California Good ole Mojave Desert.
got mine at kmart/craftsman.
Old 10-09-2008, 01:26 PM
  #29
Mossyoakman3006's Avatar
Hey man looks good, just got some lube locker seals just gonna put them on with the stock diff covers. Question for you when you say limited slip adhesive what is that and where do I get it. Also what kind of gear oil did you go with, I was thinking of going with Royal Purple. Thanks for the write up!
Old 10-11-2008, 06:33 PM
  #30
dburgette's Avatar
It's always tempting to fill more than stock. Whatever you do...Don't do! Stay with the stock amounts in the rear and front.
Quick Reply: Solid Diff Cover Install
