Six-dollar dash upgrade
#81
I have a Rescue Green, and am debating whether to paint them to match the body, or to paint them Silver....
Any recommendations?!
Also, lets see some more pictures of those speaker grilles and tweeters painted!
#82
Coats
I did three coats of each, with time in between coats. If I remember correctly, the adhesion promoter says to paint no longer than ten minutes after the last coat. Good luck.
#84
Clarification on the mod....
FYI: You have to turn the whole vent and outer ring (bezel) about a 1/4 turn to remove the whole vent as a unit then remove the plastic ring (bezel) off the top of the vent assembly. It should turn and come out easily, two of the vents turn one way, two the other. Do not use force.
#85
I meant to post this awhile back... I did this mod in Jeep Green, and like the look. I applied two coats of "touch up paint" with the small brush that comes with the paint, let it dry, and then used some Krylon clear coat to seal it in... it looks pretty sharp, but I think I may sand it smoother and then hit it up with some more clear coat. Props to armycop for the great idea!
#86
Using the body color would look great on just the vents...but I like what Wolf did with the tweeters/speakers/vents with the silver. I think if you did all those pieces with the body color it'd be too much...
#87
Same here. Just did this tonite. Also pained the 2 large plastic "thumb" screws that secure the front 2 pieces of the hard top.
#88
#89
I'll post some later tonite, they look really good IMO. Unfortunatly I'm going to have to re-do all my vent rings because the "Clear coat" I picked up left the colour a bit washed out :/
#90
Ditto - After posting yesterday, I decided to use my Dremel with its polishing head and "sand" the clear coat... that went OK, but then I went really heavy on the clear coat, and as a result I kind of "muted" the color...
